And as Chuck said to me about my lead sled MTOW 600kg/1320lb touring gyros, "DWs cannot handle that weight with their narrow chord/solidity disc ratio." It appears in all other scenarios, except mustering, they are excellent.Aussie Paul.
You have to wonder why alloy blades would be not be perfectly balanced given that most of them are extrusions which should all be exactly the same for every foot of length. Rob has way too much happening & its a miracle he can build a house / rotors / props/ gyro"s
