I"m replying about your statement on 4 sale section Tony. (Don"t want to clog 4 sale with tech. talk) The fuel pump had crap in the valves because the filter was on the output side instead of the input side causing only 2 lbs. of pressure. On my ej25 I have wired the fuel pump directly to ignition based on the KISS system.
Reply to Tony re. fuel filters
I knew you would have it sorted max, but as paul has said is it filtered correctly into what ever pump you have , have you checked the pump pressure, cause my car still run but was just slow.[ the pump pressure was low, nothing else was changed other than resetting the "puter to have the correct fuel pressure again.] I don"t know nothing about nothing but I"d love to be the one to sort your problem. that"d make my 2014.
