I thought I had a thread already go'n on this topic but I can't find it[?].[must av been on the yank forum]After a few hours fly'n time accumulated over the last coupla years I'v tryed only two types of props, the common Warp Drive and the less common Ivo Magnum, the latter being much wider chord and rated for upto 700hp.Both where coupled to a 912 Rotax.If your interested read on, if you don't give a ****, then don't.[
]The three configurations I can compare are[ and these arn't formal tests, only observations based on performance.] WD / Ivo mag 2bl / Ivo mag 3bl.DIA 68" / 62" / 62"MAX T/ORPM 4900 / 5300 / 5100CruiseRPM[50k] 4400 / 4200 / 4000MAX clmbrate 750fpm / 850fpm / 1000+fpmFuelburn 14-15lph / 13-14lph / 11/12lphThe wider, shorter Ivo blades are more efficiant and convert more power into thrust, are much quieter and because of the smaller diameter, I can drop the plant a few inches to lower the TL without make'n room for a big prop by reconfigur'n the hole machine.[}
]Ignorance is bliss............but only till you realise you were.You can always get the answer you want, if you ask enough experts.
