Put a new C box on my gyro and was torquing up one of the eight bolts that go through the box into the alloy backing plate [there are 4 inside the box and 4 outside when it didnt feel quite right however I gave the bolt one more quarter turn when "bang" went the bolt and a sickening feeling went through my stomach. Using a pair of pliers, I grabbed the bolt head and felt resistance so I gently tried unscrewing the bolt and out it came. There was one very relieved fellow there I can tell you !!!!After examining the bolt hole and the thread of the bolt, I got one of the bolts from the old box and tried again, this time there was no binding and the bolt torqued up as the other 7 had done before.Hopefully there will be a photo of the bolt attached and perhaps someone might comment on what happened. I followed the books instructions !Image Insert:
60.32
60.32
but it was the first time ever using a torque wrench....and the last, I will go back to the old way !!Will do that Nick and yes, I know there are dodgy bolts and that was one of them, just frightened me when it let go !!Brian
