Yep. I had one on a single seat back in the early 90"s and it worked well.I just fill it by draining from the main tank and pump back to the main tank when I need it.
Little Wing build
Just curious Murray.I recall when you described your building of "Tugger", you originally had it as a taildragger design.I believe you said that "due to a number of reasons" you changed the design to a trike undercarriage.Now, obviously, the Little Wing is a taildragger.What were the reasons that you ditched the taildragger design on "Tugger" but you don"t seem to mind on your Little Wing?I"ve noticed that taildragger gyros tend to take off differently (i.e. they can"t rotate on the maingear) and so tend to do a "tail take-off" (much like a tail-first landing, which, I believe can cause issues if you muck it up!) Are taildragger gyros generally built with reinforcing on the tailwheel for the added stress on take-off?Thanks again.
