At our last Hunter Valley Gyro Club flying weekend, I ran a bit if a quiz after dinner on Saturday night. And wow did the blackboard get a work out. You know what it's like ask 10 gyro pilots the same quetsion and get 234 different answers. But the main thing to come out of it was a lot of very good discussion, and each one of us pilots and students learned something from it.Here is a few of the questions.... see what you think.1.9. How do you judge the wind speed and direction in the air?1.23. Your first flight of the day was at 8am and 18 deg C. At 11am your about to fly again with a temperature of 37 deg C. What differences would you expect in aircraft performance and flying conditions for this flight?1.24. You pre-flight your machine, but what about yourself? What should you check about yourself before you get into the seat? (eg: suitable clothing1.26. Before going for a local flight, what information should you tell the duty pilot?2.4. What happens to the rotor disk as you increase speed in a gyro? 2.5. Why is it unwise to fly fast in bumpy conditions?2.13. You land at a friends property and as you taxi towards the hanger, a dog runs towards your gyro. What would you do?2.33. What do you check prior to starting your engine? Do you use a checklist?2.34. What are the checks you do prior to taxying? Do you use a checklist?2.45. You normally fly area sea level, but you are trying a new location at 4900 ft AMSL. What differences do you expect in aircraft performance, and would you alter any of your airspeeds for take-off or landing4.2. What is the most difficult obstacle to see during a forced landing?4.6. Just after take off you find yourself at 100 ft AGL struggling to climb, you pass the airfield boundary fence and your engine stops. What do you do?4.20. When your engine fails, how much altitude do you require to complete a 180 degree turn?4.22. At what stage of the flight is the engine most likely to fail? Why? Hope these have stimulated some thought.[
]Ross B
]Ross B
AVIATE) Airspeed is priority #1. Get that nose down to try to gain some approach airspeed.2
