Hi TonyYou have to go down below the text box and there is "Additional Options" click on that and then "Attach" will become visible.Then click on "Choose File" which will take you into your computer directory.Then double clip on the file you want to attach.You must click on "Attach" again to start the process again for additional files.Hope it helps ;DTimC
Home Built
ok thats the closest ive been to getting it . it was trying too , been awhile now since mitch tried to explain it me aslo, [ thanks to both], i have to reduce the size which it does say to do but i was hoping.[ magically] that it would be right, any one with an easy to understand set of instructions now on how to reduce it?????? yeah i know im not on the right topic for this.
I thought I had seen it all - I was wrong, have a look at this video. Beggars belief!!!!http://www.youtube.com/watch?v=gsfeN...eature=related
Hi TonyUsually the first thing I do is re-size my photos to be no bigger than 200K each and save them into my ASRA folder on my computer.Then I go onto the ASRA site and type in what I want to say.After I have finished typing I then scroll down to the bottom and find the "Additional Options" and attach the photos.TimC
HiAbout to start on the rotor head - I have a set of plans for the head, but it does not specify which bearing to use. Any one able to tell me the spec for the bearing in their rotor head?If anyone has some alternative drawings of rotor heads I would appreciate them as a sanity check
!Thanks for your helpTimC
