I know its along way off yet and anything can happen between now n then, but i'm plan'n on buzz'n over next year, if time permits.[
]Wot I need to know is, once i'm across the desert [the easy bit], wot am i in for when i hit the populated areas east of Birdsvill??I'v ordered WACs for the job, but they don't tell you where the power lines, shotgun tote'n cockies and wayward FWers are.[}
]Also, isn't there a mountain range sumwhere east o here, a high one[:0]?? BTW, anyone who wants to cum along is most welcome.[ itd help break the monotoney of 700 odd sand hills between ere n Birdsvill[
].]Ignorance is bliss............but only till you realise you were.You can always get the answer you want, if you ask enough experts.
]Flying the right side up in Canada
