Hi Guys,The new machine has an ej25 with the autoflight box.What additives can I run in the gearbox and the engine to protect things and make things run sliperya.
Additives
The newer 912 and 914"s have a slipper clutch in the gearbox which uses the same oil supply as the engine, anti friction additive will adversly affect the opperation of this clutch. The clutch is there to prevent damage to the crank in the event of a prop strike.Hope I"m not clear as mud ???regards
