At the risk of another one of Ozy's chook attacks, here is a little progress made after I told everyone to go and get ...... while I fix my gyro:When you are welding around / on your gyro this is a precaution I used. The seat tank bleed line is plugged off as shown, I also filled the seat tank up with argon out of the mig welder bottle to 'inert' the fuel tank, ie, there should be no oxygen in the tank after a purge with argon (they do this at the RAAF base when working on the FA 18's. Always have an extingusher on hand when welding on your gyro, lest your dreams go up in smoke:Image Insert:
71.32
