May also need a tool to extract the output shaft bearing as there doesn"t appear to be much room to fit a conventional puller.Keyed n tapered shaft, mate, a 14lb sledge dose the trick.Just one well directed gentle tap n its dun.
Thanks Birdy, Moreys is really thick plus the directions recommend around 25% max, depending on application.Miles was saying similiar about using Mack 140 gear oil.All good information.
Your spoton Adrian.Its one thing for ol grandma to putt round do"n 500 hours a year, but its a different game if the machine is do"n 500 hours at WOT 50% of the time.Birdy, just so I get this right, your saying Waddles has a fat rear end and flies like an old grandma, or he is an old grandma?Graeme.
